so i booted up my pc and it says that its had to stop due to power serge i phone up evga and the rep said the mobo is just sensitive but im not sure what to believe as they G2 is one of the most reliable psu's what do you think?
Laptop Macbook Pro 15" 2018 With Touchbar
CPU  AMD Threadripper 1950X Motherboard Asus Zenith Extreme Ram G.Skill Trident Z RGB 64GB (8x8GB) DDR4 3200MHz GPUs 2X MSI 1080TI Seahawk X  Case Cooler Master Cosmos C700P Storage  Corsair NX 400GB Pcie SSD / Samsung 850 Evo 1TB / WD 4TB HDD(W/Optane) PSU Evga SuperNova G2 1600W Cooling  EK Phoenix TR4  Keyboard Corsair Vengance K95 Rgb Cherry MX Blue Mouse  Logitech G502 Lightspeed W/ Powerplay Sounds Corsair SP 2500 / Beyerdynamic DT990 / Schiit Stack  Display  2X Acer Predator X34p 3440X1440
https://linustechtips.com/topic/526587-psu-power-serges/
Happens if you have a weirdly wired house. Try switching all the lights on in your quarters.
https://linustechtips.com/topic/526587-psu-power-serges/#findComment-6989428
Sounds weird but i dont think this will affect me i have a surge protector in-between the psu and the wall.
https://linustechtips.com/topic/526587-psu-power-serges/#findComment-6989449
Asus' Anti-Surge feature are rather finicky and are notorious in giving false reports. You should be able to disabled in the BIOS, and unless you are actually experiencing some power / stability issue, I wouldn't worry about it. In fact, even a forum rep at Asus stated that you could disable it: https://rog.asus.com/forum/showthread.php?48472-Is-it-ok-to-disable-asus-anti-surge&p=411090&viewfull=1#post411090
https://linustechtips.com/topic/526587-psu-power-serges/#findComment-6989452
Hmmm...
Have you tried unplugging the PSU cables and replugging them back into the wall AND motherboard?
https://linustechtips.com/topic/526587-psu-power-serges/#findComment-6989460
Hmmm...
yeah i rebuilt the system an hour ago
https://linustechtips.com/topic/526587-psu-power-serges/#findComment-6989471
