Cooling a Cooler Master Silencio 550
Solved by noisebomb44,
One last thing - how much OC potential do you think I'd get out of the 4790k once I've got some proper air cooling installed, because I might want to OC it in the future? Have you got any recommended fans I should get?
I found this
4.2Ghz is a guarantee according to them, and you can probably go further if you really want to
Systemfans are pretty personal, if you are like me and prefer it to be quiet over having better raw performance and maybe even a lower price, you should probably get noctuas system fans or something like it
If you prefer raw performance and a cheaper price over silence, you will have to either google it or ask someone else on this forum, ive had no experience with that yet
