Hi,
I am planning on making a pc to play games on nvidia surround. Not any high or amazing quality, but just able to play games on surround with medium to ok quality. I am planning on scrapping the CPU, HDD, and ram from my current pc.
Here are the parts i want (and have) for the build
931gb Seagate st1000dm003 (sata)
Intel core i7 4790 @3.60ghz, haswell 22nm tech
16.0gb Dual-channel DDR3 ram@798mhz
Asrock z97 LGA motherboard:  http://www.newegg.com/Product/Product.aspx?Item=N82E16813157501&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-TechSource-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=7899552&SID=
$89.99 (after rebate and current sale)
Hxi7501 corsair PSU (750 watt): http://www.corsair.com/en-us/hxi-series-hx750i-high-performance-atx-power-supply-750-watt-80-plus-platinum-certified-psu
$179.99
Asus gtx 970: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121899&nm_mc=OTC-Iceleads&cm_mmc=OTC-Iceleads-_-ASUS-_-Video+Card+-+Nvidia-_-14121899
$349.99 (I think)
Nzxt source 210 Mid tower case (black):http://www.newegg.com/Product/Product.aspx?Item=N82E16811146075&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-TechSource-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=7899552&SID=
$39.99
Please tell me if these parts will work. After this I will probably have $1,000 usd in my bank account. Side note should I get a case with a side window? Thanks for helping me out! It means alot!
Also, should i get an SSD aswell?
https://linustechtips.com/topic/526291-first-custom-pc-build/
So total budget minus cpu and ram is 1500? Way more than needed. Also check out pcpartpicker.com I'll get one together
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/526291-first-custom-pc-build/#findComment-6985550
looking good:) maybe you might want to get a cooler looking case, but thats not necessary by any means. I seriously recommend a window, but I hate the acrylic windows. Phantex just announced a new Enthoo Evolv with a tempered glass window.. maybe wait for that? thats what i'm doing:) then you can save more money anyway.
I'd say budget for a 120 or 240GB SSD. its honestly SOO much better.
https://linustechtips.com/topic/526291-first-custom-pc-build/#findComment-6985575
CPU: Intel Core i7-4790 3.6GHz Quad-Core Processor  (Purchased For $0.00)
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard  ($79.99 @ SuperBiiz)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  ($69.98 @ Amazon)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($309.99 @ SuperBiiz)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($64.99 @ Directron)
Total: $594.94
Generated by PCPartPicker 2016-01-13 00:11 EST-0500
AMD has a surround just like Nvidia. The monitors if you don't have them should set you back about say 600 USD. Make sure 1080p, ips, 60hz (use pcpartpicker.com)
https://linustechtips.com/topic/526291-first-custom-pc-build/#findComment-6985581
You don't need a Z97 motherboard for a locked chip, the PSU is overkill, and get a 390 instead of a 970. I base the SSD on how patient you are with your computer booting up.
eh. PSU allows for upgradability if he wants in the future, but if you're not get something with less wattage. You could also wait till just a little later in the year and the new graphics cards will release, but honestly preformance increase between an R9 390 and a GTX 970 is marginal. its really what power you're willing to use (or brand loyalty, AMD could use some love)
https://linustechtips.com/topic/526291-first-custom-pc-build/#findComment-6985601
Hi,
Start here, get a free-sync display if your budget is higher
PCPartPicker part list: http://pcpartpicker.com/p/D3PCNG
Price breakdown by merchant: http://pcpartpicker.com/p/D3PCNG/by_merchant/
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($242.99 @ SuperBiiz)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($78.88 @ OutletPC)
Memory: Corsair 16GB (2 x 8GB) DDR3-1600 Memory  ($78.99 @ Amazon)
Storage: Sandisk Ultra II 480GB 2.5" Solid State Drive  ($133.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.98 @ OutletPC)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($308.99 @ SuperBiiz)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($34.99 @ Micro Center)
Power Supply: Rosewill Hive 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($69.89 @ OutletPC)
Total: $998.70
Generated by PCPartPicker 2016-01-13 00:35 EST-0500
https://linustechtips.com/topic/526291-first-custom-pc-build/#findComment-6985660
Total: $594.94
Thanks for helping me out. Will the R9 deliver medium graphics for surround? My monitors are 1920x1080, 60hz and Ips so Im covered there. I dont know much about amd graphics cards. can you explain them to me? Thanks
https://linustechtips.com/topic/526291-first-custom-pc-build/#findComment-6991781
You can easily play demanding titles at Ultra 1080p with a 390.
https://linustechtips.com/topic/526291-first-custom-pc-build/#findComment-6991794
I'm considering getting a windowed case, I'm just kind of worried that the build might look mediocre or something. Is this case good? It looks great http://www.amazon.com/gp/product/B00I6BJATW/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B00I6BJATW&linkCode=as2&tag=techs096-20&linkId=DEL37WUDW4E2HVQI
https://linustechtips.com/topic/526291-first-custom-pc-build/#findComment-6991821
Total: $594.94
The only problem is that the gpu you recomended, has mainly display ports and i only have hdmi, vga and dvi-d on my monitors
https://linustechtips.com/topic/526291-first-custom-pc-build/#findComment-6991910
It's from June, and is part of the newest family of AMD cards.
Sweet! I looked at the website and it looks really nice, also it looks like it can handle surround or eyefinity no problem. Would it be hard to get all the drivers on my hdd im going to transfer when it already has nvdia drivers?
https://linustechtips.com/topic/526291-first-custom-pc-build/#findComment-6991932
Just uninstall the Nvidia drivers first, and you should be fine.
https://linustechtips.com/topic/526291-first-custom-pc-build/#findComment-6991941
Oops, just assumed you were running 1. You won't be getting max settings with the 390 (You'd need a 980 Ti), but they should run at medium.
would converter cables slow down the fps or performance?
As long as you aren't converting to DVI or VGA.
https://linustechtips.com/topic/526291-first-custom-pc-build/#findComment-6991981
With this PC now im thinking of getting the nzxt s340. Is it hard to color coordinate parts while still making sure they are compatible. I'm thinking of making a blue themed PC. Also does the NZXt s340 have space behind the motherboard for cable management?
https://linustechtips.com/topic/526291-first-custom-pc-build/#findComment-6992072
Reject Aesthetics, Otherwise just look at 4k benchmarks for the 390 and add like 25% I guess, should be about right for 3 1080p surround, but the 390 should be fairly capable, AMD cards in general tend to do better at higher resolutions probably in part due to more memory bandwidth.
https://linustechtips.com/topic/526291-first-custom-pc-build/#findComment-6992944
I'm kind of confused on what you said, reject the color coordination and focus more on good functioning parts? is that what your trying to say?
https://linustechtips.com/topic/526291-first-custom-pc-build/#findComment-6992988
Well ya, it's not like it really matters what your PC looks like
https://linustechtips.com/topic/526291-first-custom-pc-build/#findComment-6993098
