Hi guys,
I m going to upgrade my CPU Cooler, now I have a DeepCool Theta 32 PWM wich I saw is not really good, in GTA V I have somewhere in 80-90 degrees..  I asked a lot of people and most of them told me that the Master Hyper 212 EVO is good and cheap . So , guys, what do u think about that? It`s a good cooler the 212 EVO?
https://linustechtips.com/topic/526011-cpu-cooler/
I would definitely go for the 212 evo if your not overclocking, great cooler at a great price.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/526011-cpu-cooler/#findComment-6981457
whats your cpu?
Tsubasa (The 7680x1440 beast): CPU: Intel i7 8086k | Cooler: Fully Custom Rigid Loop MOBO: Asus Z370-I ITX | GPU: Nvidia Titan Xp Star Wars | RAM: 32Gb 2x16gb Gskill Trident Z RGB | SSD: Samsung 1TB 970 Evo Nvme, 2TB Micron Sata SSD | Case: Fractal Design Nano S | PSU: Corsair SF600 With Full custom cables
https://linustechtips.com/topic/526011-cpu-cooler/#findComment-6981459
Hi guys,
cpu?
https://linustechtips.com/topic/526011-cpu-cooler/#findComment-6981463
I will overclock my cpu but not too much cuz i have i7 3770 , the non-k version
the 212 evo should still be fine then.
https://linustechtips.com/topic/526011-cpu-cooler/#findComment-6981480
212 should be just fine then
https://linustechtips.com/topic/526011-cpu-cooler/#findComment-6981496
212 will be fine. Ps get some duck tap and cover up the gap in between the fan and fins.
Systems built (personal) | 1. Bad Wolf (Has passed on to PC Heaven): https://ca.pcpartpicker.com/b/zX9WGX |  2. Red Husky: https://ca.pcpartpicker.com/b/Mwhypg
Systems built (for commission) | 1. Red Fox: http://ca.pcpartpicker.com/b/W4LD4D | 2. Not Namedhttp://ca.pcpartpicker.com/b/TMhqqs 3. Bad Wolf 2.0: https://ca.pcpartpicker.com/b/7p8Ycf upgraded Bad Wolf to an I3-7100 for my friend as a gift|
https://linustechtips.com/topic/526011-cpu-cooler/#findComment-6981549
You can't oc the 3770 outside of raising the base clock--this wouldn't be much and could compromise stability.
Can you link us to where you're shopping? There may be better alternatives available.
https://linustechtips.com/topic/526011-cpu-cooler/#findComment-6981554
I didn`t bought it from a site, I bought it from a friend .. thx
https://linustechtips.com/topic/526011-cpu-cooler/#findComment-6981701
