So, I got an idea a couple of days ago and I've been doing some research, the thing that I plan on doing is: make 2-3 mining PCs, and let them do their work.
This is the thing that I am interested in. Mining uses GPU power and all you need for a mining PC is a good GPU. Is it a good idea to like, get a couple of HD 6870s and put them in rigs that have a Celeron, a gig of ram and an 80 gig hard drive, while having a motherboard with PCI-e gen 3, because mining, as I said uses the GPU, right? I shouldn't need a better CPU for that.
https://linustechtips.com/topic/525608-starting-a-mining-operation/
i don't know much but i can say those cards have probably done hours and hours of mining already.
Main PC: Core i5 4670 | MSI Mpower Max z87 | G.Skill Ripjaws 2x4gb | Stock intel cooler | PNY GTX 770 2gb (hoping to upgrade) | Seagate 1tb 7200rpm | Corsair RM850 | Corsair Carbide Air 540 | PCCG custom sleeved black/yellow extensions | Corsair K70 Cherry MX Blue | Corsair M45 |
Phone: LG Nexus 5 | Headphones: Audio Technica ATH-PDG1, Shure SRH440 | Laptop: Asus 303la (i5 model, 1600x900 res) | Motorbikes: 2004 Sherco 290i, 2013 Husqvarna CR125 | Xbox one
You're going to need a LOT more power to make it even worth your time and electricity bill.
Scratch that, the electric bill will be more than you make.
I don't think that's going to be a problem since I've got 4 PCs running all the time
Actually there's a store that sells, I can't say new but unused 6870s
For Christ's sake do 30 seconds of research.
https://alloscomp.com/bitcoin/calculator
https://litecoin.info/Mining_hardware_comparison
Even with 1000 of those cards you'll make a penny a day.
EDIT:
For BTC mining performance: https://en.bitcoin.it/wiki/Non-specialized_hardware_comparison
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
Crypto-mining hasn't been profitable for quite a while now, regardless of hardware. All costs implied in starting mining far outweigh the mining yield.
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
