Bottle neck help pls
Solved by CrazyWhiteShow,
is this the PC that you got?
Strange and first time i ever see Dell use a APU + GPU for a desktop
for a monent i was thinking you got a Laptop APU
Looking at the GPU load of 100% and 30-50% CPU usage is OK
that is unless the values are reversed like CPU load of 100% and 50+% GPU load means the CPU is limiting the GPU
but the APU and GPU combo is still balanced IMO
the FX-8800P is pretty much similar to the A10-7870K, not sure if you can OC the APU thou
the PSU looks like a SFX which only has maybe 250-300 watts of power
these are things to consider when you want to upgrade the GPU
adding a SSD and swapping out the RAM to faster kits will help the PC
That is what I got lol. Also thaks for the help
