I am using Windows 10 MSI Z97A Gaming 7 MOBO  Bios V1.11    MSI Command Center Vers. 1.01.08 I would like to know if there is a way to keep my fan profiles saved at all times. Every time I shut the computer off I lose my fan profiles and I have to load them again.  I have it enabled to launch at Startup and I have my fan profiles saved but the problem is every time I shut my computer off it forgets my settings and I have to load all of my saved fan profiles. I want my fan profiles to stay loaded so that I dont have to mess with it and it will stop going back to default settings. What am I doing wrong or am I supposed to reload all of my fan profiles everytime I boot and I dont want to change my BIOS settings I want to be able to control my fans through software that I can change on the fly. I have tried Speedfan but I think that MSI Command Center is conflicitng with it and I am not shutting off MSI Command Center for Speedfan. Speedfan doesnt work with the MSI Command Center it seems like MSI Command Center overrides it maybe? Im not sure.
Thanks
https://linustechtips.com/topic/525531-using-msi-command-center-help/
Not sure if the MSI motherboard has this, but you can change the fan speed through the BIOS. I do this with my Asus motherboard.
MSI%20Z87A-GD65%20Gaming%20BIOS%2031%20-
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
Try setting your fan profiles in your BIOS. It helped for my CPU temps and I got a MSI Z97 Gaming 5 Motherboard. Just save it as a OC profile to make sure its saves right.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
Only way is to reboot and adjust fan profiles that way.
