Hi is it worth getting an itx or m itx pc or a laptop the pic/laptop i think I'm leaning toward a laptop as I can sell mine and get a better one but I'm stuck so what do people think I Will also use the laptops as a portable film box
Thanks in advance tomic
Red Fury: Cpu intel i5 4960k GPU 1060 6gb, Cooling  noctua dh15 storage 1tb sshd 250gb ssd mobo gigabyte z97p-3 case fractal r4 ram hyper x fury red 8 gb psu 550w xfx ts os win 10 monitor lg 25um56
https://linustechtips.com/topic/525386-lan-box/
If your looking for portability then the obvious choice is Laptop. The only bad thing is that laptops, compared apples to apples with desktops, will be more expensive that a desktop with the same specs.
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
https://linustechtips.com/topic/525386-lan-box/#findComment-6973495
The real question is, what you will use it for? If you are traveling much, laptop is better as you don't need to carry keyboard and monitor with you. Or cables to monitor. Lan Box would indicate that you are looking something smaller than tower build to take on LANs and possibly gaming on it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/525386-lan-box/#findComment-6978382
