First build
Go to solution Solved by The Official Czex,
is it complicated using the BIOS, I do have a fan controller, if that matters
Nope. That's how you'll be overclocking anyway. It's simple. Just click around in BIOS for a while to familiarize yourself with everything. If you have any questions, just ask us; we're always here to help!  :D
Where's the parts list?
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/525336-first-build/#findComment-6972814
mmmm yes, my favorite build. The all White
I know the PSU is good but is the wattage enough and give ur opinions about the case
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/525336-first-build/#findComment-6972840
yea, i recommend getting a different power supply, the wattage is enough but the PSU isnt the best. get a Seasonic PSU
https://linustechtips.com/topic/525336-first-build/#findComment-6972855
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($103.99 @ Amazon)
Motherboard: MSI Z170 Krait Gaming ATX LGA1151 Motherboard  ($147.98 @ B&H)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($84.88 @ OutletPC)
Video Card: EVGA GeForce GTX 980 Ti 6GB FTW ACX 2.0+ Video Card  ($597.99 @ NCIX US)
Case Fan: Corsair CO-9050017-BLED 66.4 CFM 140mm  Fan  ($15.89 @ OutletPC)
Case Fan: Corsair SP120 57.2 CFM 120mm  Fan  ($12.99 @ Amazon)
Case Fan: Corsair SP140 49.5 CFM 140mm  Fan  ($13.59 @ Amazon)
Fan Controller: NZXT SENTRY 3 Fan Controller  ($29.99 @ SuperBiiz)
Monitor: Dell S2716DG 144Hz 27.0" Monitor  ($599.00 @ Adorama)
Keyboard: Rosewill Apollo RK-9100xBBR Wired Gaming Keyboard  ($99.88 @ OutletPC)
Mouse: Logitech G502 Wired Optical Mouse  ($64.99 @ Newegg)
Headphones: Sennheiser HD 558 Headphones  ($89.99 @ Amazon)
Other: Blue yeti ($110.00)
Other: D-Link DIR-855L Wireless N900 Simultaneous Dual-Band Gigabit Router w/ SmartBeam Technology IEEE 802.11a/b/g/n, IEEE 802.3/3u/3a ($40.00)
Total: $2985.09
Generated by PCPartPicker 2016-01-11 14:04 EST-0500
That PCIe SSD will make boot times slower than with a SATA III based SSD due to PCI lane configuration times during preboot.
https://linustechtips.com/topic/525336-first-build/#findComment-6972864
... It's a great PSU...
850W is recommended for two 980tis in SLI so one is more than enough. 650W for the EVGA G2/GS/GQ would be a better way to spend your money unless you plan to throw another in later.
https://linustechtips.com/topic/525336-first-build/#findComment-6972904
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($419.41 @ Amazon)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory  ($94.88 @ OutletPC)
Storage: Western Digital BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive  ($149.89 @ OutletPC)
Case: Cooler Master MasterCase Pro 5 ATX Mid Tower Case  ($139.99 @ Amazon)
Power Supply: XFX PRO Black Edition 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($124.99 @ Amazon)
Total: $2985.09
unfortunately I'm sticking with either EVGA or corsair with the PSU and with ssd real benchmarks proved the pci ssd to be faster I did research
https://linustechtips.com/topic/525336-first-build/#findComment-6972911
Faster once in the OS, but PCIe boot devices take a while to initialize over SATA III boot devices. It'll take longer to boot despite the speed.
I know this from experience (I own the 512GB model).
Also, SeaSonic (the OEM for XFX PSU' s) are the most reliable power supplies you can buy.
https://linustechtips.com/topic/525336-first-build/#findComment-6972941
Yes I'm going to sli in the future
OK then 850W is good. If any of the aforementioned EVGA options are cheaper then go for one of them.
https://linustechtips.com/topic/525336-first-build/#findComment-6972950
well I prioritize it's speed in the OS more than boot time, and can u link me a seasonic PSU that's 850w and 80+platinum
https://linustechtips.com/topic/525336-first-build/#findComment-6972973
Does it need to be Platinum rated?
That XFX unit I suggested is made by SeaSonic and it's as reliable as they come.
https://linustechtips.com/topic/525336-first-build/#findComment-6972985
yup I need it to be platinum
Any particular reason you want to spend the 70 USD delta for an 80+ rating up?
https://linustechtips.com/topic/525336-first-build/#findComment-6973014
the corsair h105 doesn't have corsair link to monitor the pump and fans, however it is 8mm thicker than the h100 and I don't know what to choose
https://linustechtips.com/topic/525336-first-build/#findComment-6973067
what do u mean by delta
Cost difference. It's not worth seventy dollars for a slightly higher 80+ rating. 80+ ratings and wattage do not affect performance.
https://linustechtips.com/topic/525336-first-build/#findComment-6973516
Corsair Link is terrible. Trust me, you don't want it. You can us BIOS to control fans and monitor the pump.
https://linustechtips.com/topic/525336-first-build/#findComment-6973519
https://linustechtips.com/topic/525336-first-build/#findComment-6973612
i use the PSU that u linked above right
https://linustechtips.com/topic/525336-first-build/#findComment-6973725
