Hi. First post here so hopefully this is in the right place.
Inspired by linus's video I'm planning to build my first nas and incorporate some degree of gaming. Was hoping the helpful people here would be able to tell me if this case will work ok.
https://www.xcase.co.uk/4u-rackmount-server-cases/x-case-studio-4-aluminium-locking-front-long-cards-support-450mm-deep-69-99-x-case.html
Thanks in advance
Tony
https://linustechtips.com/topic/525224-case-advice/
This a rack-mounted case. Not sure if that's what you want.
Any case with sufficient drive bays would work for a nas, then you can look for premium features if your budget allows for, like hot swap bays.
Also what size of case do you want?
https://linustechtips.com/topic/525224-case-advice/#findComment-6971213
@prolemur
Yea was after a rack mount case. Have built a rack unit in my front room to hold all a/v kit.
Was looking for a case under 500mm(19") really.
Damn, that's pretty sick. It looks like that case would work, "long card support", atx power supply, atx board
https://linustechtips.com/topic/525224-case-advice/#findComment-6971467
