Case recommendation
All cases these days are pretty much built with removable dust filters and some modularity in mind (such as removable HDD brackets for better airflow etc.).
From that point in on it depends on what you like and if you want to "future proof" your case (future proof in " because there is no such thing...).
Personaly I'm going with a Phanteks Enthoo Pro M acrylic window edition. Brand new case, same as the Pro M, accept the whole side is acrylic so you can see everything.
Buuut because you are only purchasing from this specific webpage (I'm guessing a bundle?) I'd go either with the Corsair C70 or the Coolermaster CM storm 2 if you like going to LANs and need to transport your case quite often, or else if you're willing to add a bit more, go with the Coolermaster Mastercase 5 or Pro 5.
