I understand that everymother board is different when it comes to this, but I have the power + and power - working fine and everything else is fine , exept for the audio jack pins. I have to plug my headphones into my monitor to hear through them, and it creates a loud static noise, what can I do? my mother board is a Gigabyte Technology B85M-DS3H-A thanks
https://linustechtips.com/topic/524707-pins-from-case-go-where/
https://linustechtips.com/topic/524707-pins-from-case-go-where/#findComment-6965098
Audio jack uses a standard plug that has nothing to do with the other I/O pins.
Look for the cable with AC97 or HD Audio on the side of the plug.then plug it into the spot your motherboard manual says to (Bottom left, white, F_AUDIO).
Or you could use the motherboards rear audio jack. Front audio jacks typically cause static too due to poorly shielded and thin wires.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/524707-pins-from-case-go-where/#findComment-6965114
Look for the cable with AC97 or HD Audio on the side of the plug.then plug it into the spot your motherboard manual says to.
I the back too, no luck. and I cant hear through the front at all. As I stated, I use the headphone jack in my monitor and its making a static noise
https://linustechtips.com/topic/524707-pins-from-case-go-where/#findComment-6965129
but if you have my situation where both front and back are fucked up then just do what i told u to do ;)
this is what i use btw
http://www.roland.com/products/ua-1g/
https://linustechtips.com/topic/524707-pins-from-case-go-where/#findComment-6965133
What case are you using? older cases don't support the digital audio codec for the front connectors. They have the AC'97 codec. You could try switching from digital to AC'97 and look if the frontpanel connectors now work. there should be an option in the bios to change from difital to AC'97
https://linustechtips.com/topic/524707-pins-from-case-go-where/#findComment-6965150
Make sure you plugged the audio connector into your motherboard named "HD_AUDIO" DO NOT plug the AC'97 plug in.
post-89076-0-83878100-1452458471_thumb.j
PC:
AMD Ryzen 9 5900X | AMD Radeon RX 7900 GRE | 32 GB RAM | Arch Linux
Laptop:
MacBook Pro 13" (2019) | Intel Core i5 8279U | 8 GB RAM | macOS
Server:
Intel Core i7 6700K | 16 GB RAM | 2 TB HDD | Debian Linux
https://linustechtips.com/topic/524707-pins-from-case-go-where/#findComment-6965170
Oh, try right clicking the audio icon in your taskbar and changing the playback device to what I'm betting is something with Realtek in it.
https://linustechtips.com/topic/524707-pins-from-case-go-where/#findComment-6965175
