No idea why, but for some reason my PC will start making this random buzzing noise.
I've attached a recording of the sound.
All I have to do is touch the desk, not even apply any pressure and the sound goes, as soon as i remove my hand from the desk the sound returns. (This is what i do in the recording)
This isn't a constant sound either it comes and goes. Any thoughts?
I thought it might some vibration issues.
buzz1.wav
https://linustechtips.com/topic/524605-vibrating-sound/
If you want a real answer it is your side panel shaking from a fan
RyanTheCanadian
Network Administration / Systems Management and Security / White Hat
My computer is the definition of scrapyard wars.
https://linustechtips.com/topic/524605-vibrating-sound/#findComment-6963670
Sort of sounds like a fan hitting resonance or something. Try playing around with the fan speeds to see if they go away.
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/524605-vibrating-sound/#findComment-6963709
One thing I have noticed is that it occurs more when I'm gaming. Obviously the motherboard ramps up the fans during this time. I'm confused as this hasn't happened in like 4 years since the PC was built.
https://linustechtips.com/topic/524605-vibrating-sound/#findComment-6965355
Try setting your PC on something that's a little soft, like a towel or something.
https://linustechtips.com/topic/524605-vibrating-sound/#findComment-6965484
Yeah more in likely a ball bearing fan going out. They wobble in place and eventually could launch. Well not really. Flick some fans to see if you can isolate it. Don't rule out your power supply fan either, I once had a cable jammed into one for a few months before I found out.
https://linustechtips.com/topic/524605-vibrating-sound/#findComment-6966055
