I need a new power supply for my skylake build. I want it to be an 80 plus platinum rated PSU. Specs are: define s, asus z170 deluxe motherboard, Core i5 6600k, Trident z DDR4 16Gb memory, msi GeForce gtx 970, AND Four Samsung 250Gb ssd's. no sound card because I will be usind a dac and amp. Some fans and I need a bit of room because I will PROBABLY going to be doing overclocking
Location: Vineland, NJ, USA. PROBABLY GOING TO UPGRADE TO Core i7 6700k.
https://linustechtips.com/topic/524398-new-power-supply/
What's your budget and location?
Also, it'd be nice if you used http://pcpartpicker.com - I'll assemble your current parts list in there.
Ooh, you're going to need an aftermarket CPU cooler as the k-series Skylake CPUs don't come with them.
And also I would use an R9 390 over a GTX 970.
Sig under construction.
https://linustechtips.com/topic/524398-new-power-supply/#findComment-6961608
You don't need 80+ platinum.
Get a SeaSonic G-series 550W
Antec High Current Gamer 520M
EVGA G2/GS/GQ 550W
Corsair RMx 550W
XFX 550W
https://linustechtips.com/topic/524398-new-power-supply/#findComment-6961610
Why Platinum? The efficiency rating tiers means very little. Save some money and get a EVGA 650W GS instead.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/524398-new-power-supply/#findComment-6961617
No need for that rating unless above 1000W of power,than you will run into other issues other than effectiveness of it.600 W should be plenty for that build with the overclock,maybe get a r9 390 over gtx 970,but that is my oppinion,both are great choses,but psu 600W should be more than enough with the overclocked system.
https://linustechtips.com/topic/524398-new-power-supply/#findComment-6961630
EVGA G2/GS/GQ 550W
Corsair RMx 550W
XFX 550W
550w is too low don't you think? i mean it should be fine for stock settings but I'd give him at least 650W for both CPU and GPU overclocking.
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/524398-new-power-supply/#findComment-6961631
Assembled the list:
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($263.98 @ OutletPC)
Motherboard: Asus Z170-DELUXE ATX LGA1151 Motherboard  ($317.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($84.88 @ OutletPC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($336.99 @ NCIX US)
Case: Fractal Design Define S ATX Mid Tower Case  ($79.99 @ NCIX US)
Total: $1458.46
Generated by PCPartPicker 2016-01-10 07:53 EST-0500
Please choose an aftermarket CPU cooler to use.
https://linustechtips.com/topic/524398-new-power-supply/#findComment-6961633
it's fine
https://linustechtips.com/topic/524398-new-power-supply/#findComment-6961654
Assembled the list:
Memory: G.Skill TridentZ Series 16GB (2 x 8GB) DDR4-3200 Memory ($119.99 @ Newegg)
Total: $1458.46
I know, I will use an aftermarket cooler
https://linustechtips.com/topic/524398-new-power-supply/#findComment-6961661
look at it again
https://linustechtips.com/topic/524398-new-power-supply/#findComment-6961759
Location: Vineland, NJ, USA. PROBABLY GOING TO UPGRADE TO Core i5 6600k.
970 and i5? About 300W with overclocks can be expected. Maybe, if you go for a 390 instead, you might see closer to 400W but you're still good on a Seasonic G-series 550W or EVGA GS/GQ/G2 of about that much.
https://linustechtips.com/topic/524398-new-power-supply/#findComment-6963896
