Chassis Fan running at 1900 rpm, bios setting dont change it.
WetDoorknob
I recently built my new pc, and i love everything about it. Except for the fact that the thing is so loud. All my fans in my pc are running from 900-1200 rpm, and for some reason i have a chassis fan that is running at 1900 rpm. I've tried to change it in the bios but it wont work. I'd like to try to stay away from a fan controller since that's just another thing for me to buy. If there is anything that i can do to fix this problem without buying new stuff, that would be very appreciated. Thank you!
post-269554-0-15779800-1452414863_thumb.
Its very likely that your fan is 3pin and your mobo doesn't support controlling 3pin/DC fans at all or just in that header. You will need to get low-noise adapter or use another, working header and splitter.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
What fans are you running and what headers are they running off of?
The motherboard is a z97 extreme4 which shouldn't have this issue.
Actually, I think he's right. The case fan 2 head is below and to the left of the CPU socket and only has a 3 pin header.
The low noise adapter or finding another 4 pin fan header on your MOBO will probably be your answer.
