notebook battery
Go to solution Solved by Hans Christian | Teri,
Yes, as long as it was made for your model. The voltage will be the same but the battery time will be significantly increased (more mAhs dawg!).
As long as Dell says it is compatible (and you don't mind any extra bulk that may come with a higher capacity battery), go for it.
Desktop: Intel Core i7-5820K, Corsair H115i, Asus X99-Deluxe/USB 3.1, G.Skill Ripjaws4 32GB 2800MHz CL16, Zotac RTX 3070, Samsung 950 Pro 512GB in Angelbird Wings PX1, Samsung 850 EVO 1TB, 5*Seagate 12TB, Cooler Master V1200, Phanteks Enthoo Luxe, Windows 10 Pro. Phillips 328P6VUBREB, Corsair Vengeance K95 RGB Cherry MX Brown, Logitech G502 X Plus, Sennheiser HD700.
AYANEO 2S: AMD 7800U, 32GB 7500MHz, 2TB WD SN850X. Windows 11.
https://linustechtips.com/topic/52427-notebook-battery/#findComment-701909
It depends on your charger. If your charger doesn't support a high enough wattage, the computer may show constant warnings and might not even charge.
A 60-65 watt charger should do.
https://linustechtips.com/topic/52427-notebook-battery/#findComment-701911
Higher battery cell, doesn't require more power to charge. In the sense that if you initially pick a higher cell battery from Dell when you order it, you won't have to get a higher power adapter. The laptop is designed for it.
https://linustechtips.com/topic/52427-notebook-battery/#findComment-702336
