What do you guys think of this build to run Windows simply to run CrashPlan, nothing else. Will only act as a receiver for computer backups.
http://pcpartpicker.com/p/6QhPRB
  • CPU: Celeron 1037U (Integrated)
  • Mobo: ECS NM70-I2(1.0) Mini ITXECS NM70-I2(1.0) Mini ITX
  • RAM: 1x4Gb DDR3 1333 Mhz
  • SSD: A-Data Premier Pro SP600 64GB
  • HDD: 2x Western Digital Red 2TB (Raid 1)
  • Case: Cooler Master Elite 110 Mini ITX
  • PSU: EVGA SuperNOVA GS 550W
https://linustechtips.com/topic/524130-nas-backup-server-parts/
That PSU is wayyy to expensive for this build. A EVGA 430W will be perfect for this system and you could focus the money you save (about $50) elsewhere in this build.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/524130-nas-backup-server-parts/#findComment-6958629
I recommend FreeNAS as it has a CrashPlan plugin. It's also free (whereas, Windows is not). Just use UFS instead of ZFS.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/524130-nas-backup-server-parts/#findComment-6958674
I want to use Windows as 1. I get free copies and 2. Crashplan works perfectly, whereas on FreeNAS its not really built for incoming backups, more for backing up your NAS to their servers.
https://linustechtips.com/topic/524130-nas-backup-server-parts/#findComment-6958751
Real Back Up Solutions have ECC
Starts at around 300 for an i3 + 8gbs of ECC + motherboard
Also FreeNAS doesn't require an OS drive
https://forum.teksyndicate.com/uploads/default/original/3X/e/4/e4a03e7a255b02a1ea7c563f7e9e516250d5c960.jpg
Although if you only have 2TB of data to back up just buy a hard drive dock and plug in a drive to it every once in a while, a dedicated back up machine is rather overkill
https://linustechtips.com/topic/524130-nas-backup-server-parts/#findComment-6959008
How?
Consider a smaller, Seasonic 300W - 350W non-modular psu. Excellent reliability, lower cost. SeaSonic 350W 80+ Bronze
The build is for a client, who gets free copes through their employment if you must know
Will change PSU, I really wanted semi-mod just because its such a small case but I guess I can cram it all in  :P
Again, not planning on using FreeNAS, I don't think its worth it when I'm building a CrashPlan backup destination
https://linustechtips.com/topic/524130-nas-backup-server-parts/#findComment-6959195
