can people look over my build and tell me if they can see any problems and give me some answers to my questions
Main componats
LIAN LI PC-D666 WD black gamming pc case (will this case fit my mother board?)
Z10PE-D9WS duel cpu work station motherboard (will this mother board work with my processors and does it have the necessary stuff so I can add my drive slots and PCI cards ?)
X2 I7-5930K 3.50GHz(Haswell-E) Socket LGA2011-V3 Processor (will these processors talk to each other the way they should)
EVGA Supernova 1600 w g2 80+ modular gold power supplys unit (does this PSU have 2 motherboard power connections for the duel cpu mother board)
BLITZ Original Red 32GB (4x8GB) DDR4 PC4-28800C18 3600MHz Quad Channel Memory Kit - Red Light (does this memory have to be ECC memory to run with my processor or mother board ?)
WD BLUE Desktop 3.5 inch Internal Hard Drive (SATA, 6Gb/SEC, 6 TB, 64MB)
Samsung 850 Evo 2 TB Internal Solid State Drive
Drive slot
Enermax ECR501 USB 3.0 Card Reader
Aerocool Strike-X Panel Touch Screen 5 Fan Controller
NZXT Technologies 5.25-Inch Hue RGB LED Color Changing Controller
Samsung SH-224FB/RSMS 24X Internal DVD Writer with SATA
PCI(E)
Tenda W322P 300Mbps Wireless PCI Network Interface Card
X3 Asus STRIX-GTX980-DC2OC-4GD5 256 Bit Nvidia Gtx 980 Graphics Card (4GB, GDDR5, Dual Link, PCI Express)
TBS 6281 Dual Terrestrial HD Low-profile PCIe TV Tuner Card DVB-T2
Asus ROG Xonar Phoebus 7.1 PCI Express Soundcard
Cooling
CORSAIR co-9050006-ww air series sp120 quiet edition 120mm low noise high pressure fan dual pack
CORSAIR co-9050006-ww air series sp140 quiet edition 140mm low noise high pressure fan dual pack
Im using these fans because I intend to change to a full water cooling system in the future
https://linustechtips.com/topic/523812-needing-help-with-my-build/
Errmm please use pcpartpicker.com I can't understand a thing
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
looks good mate. Good luck with your build
I don't think this build will workout well, the PSU and RAM amounts are overkill. Plus I'm not sure wether this motherboard will work well with haswell E
Main componats
If you put this list in pcpartpicker.com, this & most of the other questions are easily answered. If you had provided links to the manufacturer's web pages for the various components the questions could have been answered with a little bit of work. As it stands you are asking people to do a great deal of work. Work you should have attempted.
A quick check of the motherboard cpu support list indicates that the cpu is not supported.
You might read Build Plan Thread Recommendations (Please read before posting)  and then edit the OP providing the necessary information. This will lead to much better and more detailed responses.
