I plan on adding a r9 390 in a couple of months, but I want to build the computer now with the money I have. Will this work if I just get these parts and build it? *hi my name is paul  ^w^**<<<friend typed this*
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($81.98 @ Newegg)
Power Supply: SeaSonic S12G 650W 80+ Gold Certified ATX Power Supply  ($90.98 @ Newegg)
Total: $669.08
Generated by PCPartPicker 2016-01-08 23:44 EST-0500
https://linustechtips.com/topic/523473-ordering-parts-tonight/
Looked good though I'd get a Cryotig H7 or BeQuiet! Pure Rock for the CPU cooler
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/523473-ordering-parts-tonight/#findComment-6951406
Any reason why you went with a Xeon?
It equals pretty much an i7-4770, no reason not to go for it honestly
https://linustechtips.com/topic/523473-ordering-parts-tonight/#findComment-6951410
You'll need a display card until you get the gpu. That xeon does not have on board graphics.
just get a 20$ display card from the bargain bin.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/523473-ordering-parts-tonight/#findComment-6951434
i have the 1230............ i wouldn't buy that cpu cooler either. the noctua with the 2 different sized famns fans on it that blows down on the motherboard and components or one similar. overkill for a 80watt processor. ( h12l or something like that ).
https://linustechtips.com/topic/523473-ordering-parts-tonight/#findComment-6951436
It's a fair point he has. Xeons have become somewhat of a status symbol for some reason. Even when presented with an equivalent i7-4770 the xeon has the added bragging rights that may justify the cost to some people. Wether or not xeons should come with bragging rights is a different story, but from many peoples perspectives they do. I can't blame him honestly as I bought three noctuas to help cool my PC when a cheaper brand would have probably done just as well for my purposes. Why? Because I can say I got a noctua.(And because I like the colors.)
Don't do drugs. Do hugs!
https://linustechtips.com/topic/523473-ordering-parts-tonight/#findComment-6951447
Total: $669.08
Xeon are excellent cpu but except for a few models, do not have an iGPU. You will need some sort of gpu to use this build.
I would suggest going with Intel Xeon E3-1246 V3 3.5GHz Quad-Core Processor. It has an integrated gpu. To meet budget, delay purchase of the Hyper 212 EVO. The cpu comes with an Intel cooler which will be fine.
https://linustechtips.com/topic/523473-ordering-parts-tonight/#findComment-6951454
If OP's only other choice was a regular 4770 then sure, go with the Xeon. If the 4770K was an available option, that would be better, higher clock speeds trump threads any day for games.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/523473-ordering-parts-tonight/#findComment-6951458
oo I really like this idea! Any downsides?
https://linustechtips.com/topic/523473-ordering-parts-tonight/#findComment-6951472
One is not going to be able to do any graphics intensive work or gaming. But that would be true of any system that lacks a discreet gpu.
Replacing a cpu cooler can be a bit of a pain.
What case will the system be going in?
https://linustechtips.com/topic/523473-ordering-parts-tonight/#findComment-6951599
fractal design define s. very roomy
https://linustechtips.com/topic/523473-ordering-parts-tonight/#findComment-6951621
