Simple water cooling question using AIO
Go to solution Solved by Atmos,
The EKWB 360 comes with an integrated reservoir, you're all good.
Can't hurt, but not required.
I recently bought all the parts seen in my profile system, I've revived most of the parts, but I haven't built it yet. The only question is if I'm using an EK Predator 360 AIO to cool the GPU and CPU, should I still use a reservoir in the system?
https://linustechtips.com/topic/523466-simple-water-cooling-question-using-aio/
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
I would. Sometimes water evaporates or gets dirty, would help to be able to see when it does though probably isn't needed for your setup
Tsubasa (The 7680x1440 beast): CPU: Intel i7 8086k | Cooler: Fully Custom Rigid Loop MOBO: Asus Z370-I ITX | GPU: Nvidia Titan Xp Star Wars | RAM: 32Gb 2x16gb Gskill Trident Z RGB | SSD: Samsung 1TB 970 Evo Nvme, 2TB Micron Sata SSD | Case: Fractal Design Nano S | PSU: Corsair SF600 With Full custom cables
How could it evaporate from a closed loop? Not saying your wrong, I'm a watercooling noob, but I'm genuinely curious how this is possible? Even if it evaporated into vapor surely it would have nowhere else to condense but inside the loop preventing any net-loss of water?
Don't do drugs. Do hugs!
well evaporate isn't the word i should have used but in a sense it fits. yes you are correct about how it shouldn't but not all loops are perfectly air tight. you may have a tiny leak that isn't noticeableand doesn't drip and over time that would cause water to escape(evaporate) and also once you take apart a loop and add to it there would be air gaps inside the loop that will eventually make it to the res in which case having a visible res would help.
Makes sense, thanks for the explanation. :D
