Help Deciding Between 2 Monitors Please
Go to solution Solved by Glenwing,
My price range is under $250 and I would like a 27" Gaming monitor. I found these two below and would like help deciding, also one has 5ms and is IPS the other has 1ms.
5ms IPS Panel: http://www.amazon.com/gp/product/B00B17C5KO?ref_=cm_sw_r_sms_awd_9jZJwbC7CD7KB
1ms Panel: http://www.amazon.com/VS278Q-P-1920x1080-DisplayPort-Back-lit-Monitor/dp/B009HNEBLK/ref=sr_1_1?s=pc&ie=UTF8&qid=1452227632&sr=1-1&keywords=ASUS+VS278Q-P+27%22
Get the IPS one, response time doesn't really mean anything.
https://linustechtips.com/topic/522811-help-deciding-between-2-monitors-please/
Unless you need that short of a latency, I say go with the gorgeous colors of IPS.
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
