FiiO E10K USB DAC vs Macbook pro
Go to solution Solved by Jacona,
That MacBook is definitely better than my shitty Samsung laptop that I use to use my E10k with. Should be negligible difference/improvement.
I don't know shit about headphones but I am pretty sure we Need your cans to answer this one
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
Do you have HD800s?
If the answer to that question is no, then no :P
But really though, unless you have high impedance headphones I wouldn't worry about it, the built in DAC is great in most regards, high impedance is where you need a separate amp like that to give a bit more punch than the mobo DAC can deliver
