Arrg! Since the windows 10 update last night my newly built (last month) PC no longer recogoninzes wi-fi. I have a TP-Link AC1750 card. I cannot get wi-fi to show up in the system setup!? I took the card out and it did hookup via ethernet cable. Now it will not notice the ethernet hook up either. I tried with and without the wi-fi card installed.What gives??
Help! I do not want to have to re-install windows and then spend days re-installing my games.
Anyone else run into this??
https://linustechtips.com/topic/521446-internet-connection-help/
did you go to windows update and let it install everything and then restart?
https://linustechtips.com/topic/521446-internet-connection-help/#findComment-6925202
either reinstall the drivers or maybe it could be that anit-virus programs could be interfering, if that doeskin work maybe reinstall windows.
New: PCPartPicker part list
Old:Intel® Core2 Quad CPU Q8400 @ 2.66GHz, GIGABYTE GA-EP43T-UD3L, 4 GB Elixir PC3 ddr3-1333,  ASUS RADEON R7 260X, Thermaltake M9, 1TB HDD, GreatWall GW550SEL 550 WATT, BENQ GW2255, Hyper T4, Samson SR950 Headphones, fiio ek10.
https://linustechtips.com/topic/521446-internet-connection-help/#findComment-6925212
This happened to me. Drivers did not work to solve the issue. I fixed it by doing a windows reset. You can keep your files while reseting windows.
Main System Specs:
  • Intel Core i5 6500 3.2GHz CPU
  • Gigabyte GA-H170-D3H Motherboard
  • Kingston HyperX Fury 16GB 2400MHz, Gskill Ripjaws 8GB
  • Asus GTX 1060 Turbo
  • Kingston HyperX Savage 240GB SSD
  • Seagate 1TB NAS Grade HDD x2
  • Thermaltake NiC F3 Cooler
  • EVGA Supernova 750 G2 Power Supply
  • NZXT S340 Red/Black Case
  • Noctua NF-F12 Fan x2
Laptop Specs:
  • Intel Pentium N3700 CPU
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Microsoft Wired 600 KB
  • Dell 2003 Mouse
  • HP Compaq LA2206x Monitor
  • Logitech X530 5.1 Speakers
  • Roland RH-5 Headphones
https://linustechtips.com/topic/521446-internet-connection-help/#findComment-6925214
I came home to find that it auto-updated. I had no connection then. I restarted and nothing got better.
Is this all from some bug in the update?
Ha! I love the new windows update!
/s
Try a system restore to before it updated the driver. You can also try rolling back the driver in device manager if it lets you.
When in doubt, re-format.
https://linustechtips.com/topic/521446-internet-connection-help/#findComment-6925256
/s
Oy. New system. I have not made a restor epoint. :( I guess resetting (restoring) will take Windows back to its original install state? I have never done a restore before. I am guessing the files will stay but all the programs I have loaded will go bye-bye.
https://linustechtips.com/topic/521446-internet-connection-help/#findComment-6925277
Windows automatically does a restore point with any major install. Check to see if there are any.
https://linustechtips.com/topic/521446-internet-connection-help/#findComment-6925285
Doesn't seem to be. Is there anyway to keep the other progams? Things like World of Warships that a long time to download and I have several.
Unfortunately none that I can think of. I had this happen to me when I was first installing win10 on my machine. Luckily it fucked up before I got to installing any large software so a re-do of windows wasn't a big deal.
https://linustechtips.com/topic/521446-internet-connection-help/#findComment-6925356
