I'm trying to set up speedfan because i just got 4 new noctua fans and would really like to have m PC as quiet as possible in the realms of safety.
I have an h100i and had my NF-s12a's attached to my rad and ny NF-a14's on the front of my r4.
I have the front 140 fans working on a curve but im having issues with the 120s. I decided to take the 120s and hook them up via y-splitter to the mobo since corsair link is trash.
In the "fans" tab in SpeedFan i have three RPM readings (which there should only be three). One for the y-splitter to my 120s, y-splitter to the 140's, and the pump in the h100i.
My 120's seem to be labeled Aux3 fan. but when i go to the "speeds" tab there isn't an Aux3 fan in there... What am i missing?
i5-4670k, Asus VI Hero, Corsair Vengeance Pro Series Red 8GB (2x4GB) @1866 MHZ, EVGA GEFORCE 780 FTW w/ACX Cooler, Fractal Define R4 Windowed (Black-Pearl), Samsung Evo 250GB, WD 1tb Blue, EVGA SuperNOVA NEX 650, Acer H236HL 23" x2, Corsair H100i, 2x Noctua NF-S12A, 2x Noctua NF-A14, Steelseries Apex, Logitech G602
https://linustechtips.com/topic/521381-having-issues-with-speedfan/
Ok, so corsair link is trash because it actually works and speedfan is great because it doesnt?
alrighty then...
well just fyi, speedfan does not always work properly with all motherboards
i would suggest you use the ASUS UEFI to set your fan curves, not any software in your OS
alrighty then...
except corsair link wasnt working. i couldn't see my fan rpm nor change them. I have seemed to figured it out after posting this anyways. i have set my curves with speedfan and I have no issues so far
then you should post your answer in the thread because plenty of people google their problems and find an LTT thread, and it wouldnt help anyone with this problem if you found a solution but didnt say what it is
the problem is that i have no idea what i did but it works now sooo
