i got a new HTC one A9, (say as you wish, i love it) and with it i bought i qualcomm quick charge 3.0 charger.
when i use that quick charger, i do not get a notification that says "quick charging" nor in the lock screen does it say "quick charging" rather than the normal "charging", however i am unsure if i am supposed to get a notification that the phone is indeed, quick charging.
to calm my nerves i downloaded an app called ampere, that measures the charger's Mah. the stock 1.5a charger does about 300 while the qualcomm charger gets 800-880, so yeah it has more power, but is it actually quick charging?
so is it indeed quick charging? or am i supposed to get a quick charge notification?
thanks.
PS. this is the charger i bought:
http://www.amazon.com/gp/product/B015ZJKWFS?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/521307-quick-charge-issue/
dont think it is on my s6 edge it says when it's quick charging.
New: PCPartPicker part list
Old:Intel® Core2 Quad CPU Q8400 @ 2.66GHz, GIGABYTE GA-EP43T-UD3L, 4 GB Elixir PC3 ddr3-1333,  ASUS RADEON R7 260X, Thermaltake M9, 1TB HDD, GreatWall GW550SEL 550 WATT, BENQ GW2255, Hyper T4, Samson SR950 Headphones, fiio ek10.
https://linustechtips.com/topic/521307-quick-charge-issue/#findComment-6923562
I don't think you would get a quick charge notification, my phone usually says how long if you leave it charging long enough
https://linustechtips.com/topic/521307-quick-charge-issue/#findComment-6923566
perhaps something to do with the new android 6.0 marshmallow
since its a new phone to the market i have found nothing on other forums, but the phone is qualcomm quick charge capable, and the ac adapter is certified.
i even tried 3 different cables.
https://linustechtips.com/topic/521307-quick-charge-issue/#findComment-6923568
i do however notice that it does indeed, charge fast, but it doesnt say quick charging.
perhaps android is trying to be more simple and relaxed, but as a tech savvy user i like some feedback :P
https://linustechtips.com/topic/521307-quick-charge-issue/#findComment-6923579
