I currently have one 144hz monitor, its 24 inch and I look to upgrade. I either plan to buy ANY of these setups and I would like to have some opinions.
1. 2 more 144hz 24 inch which makes it a triple display setup with 3 144hz monitors. (1080p)
2. 3 NEW 144hz 27 inch monitors. (1080p)
3. Buy a Ultra wide (Acer x34 OR z35) (Acer x34 is 1440p, z35 is 1080p)
I currently run 980TI SLI and I want a 144hz. I am able to go 100hz acer x34 but I will not go back to 60hz.
Can anyone help?
Cheers
https://linustechtips.com/topic/521276-need-help-with-setup-regarding-monitors/
Well, it's a preference thing, really. I personally would NEVER get an ultrawide as my only monitor, as that would kind of break the window snapping.
That being said, if all you do care about is gaming, I'd say the ultrawide offers a better experience.
"It's a taxi, it has a FARE METER."
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
a 27" 1080p display is silly.
Just get the 3 24" 1080p displays I suppose, probably with G-sync if possible, too bad you don't have AMD cards.
40" 4k would be the best route, but those are all 60hz, they're going to be much better for productivity though.
1) over 2 because 27 inches looks a bit stupid at 1080p. 3) If you can get the x34/z35 but itll probably cost you alot more than 1)
