So I was experimenting with my first ever gpu overclock on my MSI Twin Frozr R9 290. Managed to get the core clock to 1115MHz and the memory to 1400MHz stable, so I decide to try the memory at 1450MHz. Unigine lasted about 30 seconds before crashing and then nothing but a black screen. Tried restarting but I couldn't boot whilst gpu was plugged onto display, it worked again after plugging display into motherboard but I have no idea how to change the memory settings back now because all I see in MSI afterburner is the integrated gpu specs. The fans on my gpu still spin so its technically working, but how do I fix this?
EDIT: Also can't access the AMD drivers because the gpu isn't plugged in :/
https://linustechtips.com/topic/520425-help-me-fix-my-gpu/
You should have profiles for your gpu's in afterburner I think. Find them and delete them.
https://linustechtips.com/topic/520425-help-me-fix-my-gpu/#findComment-6912287
If it wont POST with your card in then it could be hardware related :(
So am I screwed? I bought this second hand along with a psu, cooler, and ram off a guy on DoneDeal (Irish version of Craigslist/generic buy and sell website) and everything except the gpu came with boxes and packaging and stuff, so I don't think I can RMA the card. I've had this for a few weeks now and everything has been perfect, only since I started to OC it.
https://linustechtips.com/topic/520425-help-me-fix-my-gpu/#findComment-6912347
Then it should be at default settings no? Might wanna try reinstalling drivers.
Unfortunately it still won't boot into windows whilst plugged into gpu, the overclock is still definitely applied as the fans are going much faster that they would before.聽
https://linustechtips.com/topic/520425-help-me-fix-my-gpu/#findComment-6912548
If you can find a way to undo the overclock, you might be able to get it to work. Also, did you try plugging it into a diffrent pcie lane?
https://linustechtips.com/topic/520425-help-me-fix-my-gpu/#findComment-6912585
Putting it in a different pcie slot seems to have fixed it. So will I just have to keep it there or is there a way to sort it out?
https://linustechtips.com/topic/520425-help-me-fix-my-gpu/#findComment-6912965
Can't you just uninstall MSI AB using the igpu or safe mode and reinstall after you put the gpu back in?
It's not a race to the bottom.
https://linustechtips.com/topic/520425-help-me-fix-my-gpu/#findComment-6913566
