Audioengine A5+ Installation Help.
Go to solution Solved by M A J O R,
Just to be sure, you're using the volume rocker on the actual speakers themselves right (or using the remote)?
I figured it out. The minijack wasn't plugged in fully but looked like it was.
I bought a set of Audioengine A5+ speakers and I'm having some installation problems (No idea with audio equipment).
I've connected the AC Power as well as the speaker wire connecting the two speakers. I've checked that the exposed wire is contacting the connectors.
Lastly there is the mini jack and the RCA cable.  I've connected the mini jack from the speaker to the green port on my motherboard IO. After this I turned them on and tried them out.
I'm getting some sound but I have to max the PC volume and it's still a very low sound. Do I have to connect the RCA cable to my PC as well? Like I said I have no idea.
If so which colored ports do I connect them to on my mobo.
Thanks in advance.
Corsair Air 540 - ASUS Maximus VIII Hero Z170 - Corsair HX850i - Intel i7 6700K - Corsair H100i Pro - Gigabyte RX 5700 XT 8GB - 32GB Kingston HyperX Fury DDR4 2400 - Samsung 860 QVO 1TB - Samsung 850 500GB - WD Black 4TB
https://linustechtips.com/topic/520069-audioengine-a5-installation-help/
AD2000x Review  Fitear To Go! 334 Review
Speakers - KEF LSX
Headphones - Sennheiser HD650, Kumitate Labs KL-Lakh
How do you like them? I'm considering them myself aswell.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
I've had the A5+ for a few years now and have nothing but good to say about them, but I'd like to point out the very poor price:performance ratio they offer in comparison to what I would argue are overall better, such as the JBL LSR305.
Granted I did not pay $400 for the A5+, I got them for under $300. if I were to do it again though for this price range, I'd probably just grab the LSR305's. The 305's offer a sound that is more crisp without distorting at higher volumes where the A5+ seems to suffer, outside of that though the A5+ has been great, although the sound is much warmer than the 305.
MSI Z97M Gaming | i7-4790k | NZXT Kraken X61 | 16GB Kingston Savage DDR3 2400
EVGA GTX1080 Ti FTW3 | EVGA G2 750 | Phanteks Enthoo Evolv | 1TB 850 Evo | 2TB 860 Evo | 22TB DS918+
Scarlett 2i2 | WooAudio WA7 Fireflies | Fostex TR-X00 | Beyer DT990 | MrSpeaker Alpha Dog | V-Moda M-100 | JBL LSR305 MK2
Amazing speakers, but expensive for what they are, thought they would need a sub but a year and half later I still haven't gotten a sub for them so...yeah.
On a similar note, god damn the new HD6's are expensive as hell, but I want them so bad >.>
Speakers - KEF LSX
