What is the best white 960 available? I'd like 4GB and I found this http://www.galax.net/GLOBAL/960exocw_4gb.html but I can't find anywhere to purchase it. Any other suggestions? I know I could paint the card, but I don't trust myself enough to do that.
Also, what would be the AMD equivalent of a 960 and which would you guys suggest?
Thanks in advance!
https://linustechtips.com/topic/519730-best-white-960/
I would say the MSI armor 960. The AMD equivalent is better, and is called the R9 380.
@mttkzk
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/519730-best-white-960/#findComment-6904314
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/519730-best-white-960/#findComment-6904320
I know Asus has a white one called Turbo.
But of its good I dont know. You can always paid to the cooler.
Doesn't look too good to me.
Main Gaming Rig:
Secondary PC:
https://linustechtips.com/topic/519730-best-white-960/#findComment-6904324
Thanks in advance!
I personally quite like this one.
http://ca.msi.com/product/graphics-card/GTX-960-2GD5T-OC.html#hero-overview
AMD's equivalent is the R9 380.
http://ca.msi.com/product/graphics-card/R9-380-2GD5T-OC.html#hero-overview
^That one's if you want it in white, otherwise I'd recommend this one.
http://www.sapphiretech.com/productdetial.asp?pid=421F760D-5247-4A25-BA5D-74A7A3139CD7〈=eng
https://linustechtips.com/topic/519730-best-white-960/#findComment-6904328
Well, this isn't about you so Meh :P
I personally quite like it, but for a white setup, there are better options.
Main Gaming Rig:
Secondary PC:
https://linustechtips.com/topic/519730-best-white-960/#findComment-6904342
I don't think it comes in a 4GB variant though.
I think it does
https://linustechtips.com/topic/519730-best-white-960/#findComment-6904361
asus-turbo-geforce-gtx960-oc-2gb-furmark
The VRMs on the Asus GTX 960 Turbo are kinda burning so I wouldn't suggest it.
https://linustechtips.com/topic/519730-best-white-960/#findComment-6904395
