Cities Skylines issue
Solved by ben dover kid,
I have experiencing some issues with cities skylines lately, my fps doesn't cross 30 mark at all, it just sits there at 30fps even in a region with no city built nothing. I also tried lowering all settings and disabling all mods, but nothing changes.
My PC specs are -
i5 4460
8gb DDR3 ram
gtx 960 4gb
Please help !!!
that sounds like vsynch put to half refresh rate. go to nvidia control panel, 3d settings, and check the vsynch there(sorry its called something else than vsynch, and mine isnt in english so i dont know what that particular one is called, but you will find it) just choose cities skylines, and go thru the settings. optionally you can reset to default settings
