LED Lights
Looking to get some leds inside my system and i'm not sure which ones to get.
http://www.amazon.co.uk/NZXT-Colour-Changing-Internal-Controller/dp/B017LOXRAC/ref=sr_1_1?s=computers&ie=UTF8&qid=1451684686&sr=1-1&keywords=nzxt+hue+rgb
http://www.amazon.co.uk/NZXT-Technologies-5-25-Inch-Controller-8c-hue0000-00b/dp/B008RWT2IY
Found these two but i don't which one to get or if there are any more out there.
https://linustechtips.com/topic/519448-led-lights/
Hue +
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
https://linustechtips.com/topic/519448-led-lights/#findComment-6901221
Hue +
yeah get the hue + the other one is an older version.
CPU: Intel Core i7-5820K @ 4.1GHZ | MOBO: Asus Rampage Extreme V Eatx LGA2011-3 | RAM: 16.00GB DDR4 G-Skills Ripjaws @2400Mhz | GPU: 2x Gtx 980 | CASE: Cooler Master Cosmos 2 | STORAGE: 400GB INTEL 750 Series PCI-E SSD/ 3TB Western Digital WDC | PSU: Corsair AXi 1200w | DISPLAYS: ASUS PB287Q (3840x2160@60Hz) And LG27MU67 (3840x2160@60Hz)
https://linustechtips.com/topic/519448-led-lights/#findComment-6901246
those are led controllers, LOL!!!
just get a cold white led strip cut it and mount it where ever u need with an on/off sitch
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/519448-led-lights/#findComment-6901269
wat, hue+ has rgb led strips
Power supplies:
https://linustechtips.com/topic/519448-led-lights/#findComment-6901296
