USB HUB
Go to solution Solved by Stefan1024,
A normal periferal does use max. 100 mA usually if it does not have a lot of LEDs.
So up to 5 devices on an unpowered hub should be fine.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
https://linustechtips.com/topic/519409-usb-hub/#findComment-6900905
