You mean Chromecast Audio?
https://www.google.com/chromecast/speakers/
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/519319-remote/#findComment-6899715
remote for what...
changing the tv channel? xD
https://linustechtips.com/topic/519319-remote/#findComment-6899719
Just volume on pc speakers
Oh that?!
God, just get a long stick with some grabbers at the end
http://www.amazon.com/New-Helping-Grabber-Extension-Mobility/dp/B00LUDMHDE
There, perfect.
https://linustechtips.com/topic/519319-remote/#findComment-6899736
well you can buy a wireless bluetooth keyboard with volume controls
or use a receiver to power your speakers, those come with remotes
https://linustechtips.com/topic/519319-remote/#findComment-6899739
Oh that?!
There, perfect.
Oh idea! Use unified remote on your phone!
https://www.unifiedremote.com/
https://linustechtips.com/topic/519319-remote/#findComment-6899745
