Will It Fit?
Go to solution Solved by W-L,
Yes but, will it fit in the front like will the USB ports in the front work?
Yes it all depends on the internal headers of the motherboard and that board will have the needed USB 3.0 and audio headers.
Alright, so I want to replace my motherboard in my Corsair c70 case. I have a Corsair c70 case and I want to install an Asus z97-a case. I just needed to know if it would fit. Thanks.
Motherboard: Asus Z97-a/USB 3.1
Case: Corsair c70 military green case
System - AMD A10 6700, Nvidia gtx 770, 8gb DDR3, 1TB, Razer Anansi (want to upgrade), Razer Taiwan (want to upgrade)
https://linustechtips.com/topic/519253-will-it-fit/
Yes it will be fine standard ATX board.
https://linustechtips.com/topic/519253-will-it-fit/#findComment-6899022
Yes.  ATX mid towers have support for ATX boards.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/519253-will-it-fit/#findComment-6899024
But will the front ports work?
Yes
CPU: i5 6600k OCed to 4.5Ghz @ 1.35v, GPU: R9 390 Nitro, Motherboard: Asus z170-A, CPU Cooler: H100i GTX, RAM: HyperX 2x8 16gb DDR4, PSU: Seasonic x650, Storage: 850 EVO 500gb, WD 1tb blue, Case: H440 White/Black
https://linustechtips.com/topic/519253-will-it-fit/#findComment-6899054
https://linustechtips.com/topic/519253-will-it-fit/#findComment-6899055
Yes
Ok. Thanks guys!
https://linustechtips.com/topic/519253-will-it-fit/#findComment-6899069
