Rig
AMD 4100
Stock AMD cooler
8gb RAM
gigabyte ga-78lmt-usb3
64gb San disk SSD
1Tb WD Red
bad 500W Psu that needs replacing
I'm using this, purely to run servers -MC and TS3 at the moment, this means that it's always on and the stock cooler and fan on the PSU are always spinning, are there any fanless heatsinks that will cool this CPU successfully?
Also who makes the PSU's that only spin the fans when necessary?
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools - Douglas Adams
https://linustechtips.com/topic/518925-fanless-cooling-am3/
Rig
AMD 4100
Stock AMD cooler
8gb RAM
64gb San disk SSD
1Tb WD Red
corsair and evga have modes where the fans dont speed till 60C i think
https://linustechtips.com/topic/518925-fanless-cooling-am3/#findComment-6895281
Corsair rmi and rmx series and evga though the evga psu are a tad bit more expensive than the rmx corsair.
Tsubasa (The 7680x1440 beast): CPU: Intel i7 8086k | Cooler: Fully Custom Rigid Loop MOBO: Asus Z370-I ITX | GPU: Nvidia Titan Xp Star Wars | RAM: 32Gb 2x16gb Gskill Trident Z RGB | SSD: Samsung 1TB 970 Evo Nvme, 2TB Micron Sata SSD | Case: Fractal Design Nano S | PSU: Corsair SF600 With Full custom cables
https://linustechtips.com/topic/518925-fanless-cooling-am3/#findComment-6895292
http://pcpartpicker.com/parts/power-supply/#m=11,14&sort=a9&page=1&e=4&p=1 what?
also one of the nofen/nofan coolers
https://linustechtips.com/topic/518925-fanless-cooling-am3/#findComment-6895329
Those arnt zero fan rpm... are they?
https://linustechtips.com/topic/518925-fanless-cooling-am3/#findComment-6895404
It's a 95 watt CPU, so you can't cool it passive if you have 100% load for extended period of time.
The CR-95 should somehow hande the CPU but you need a case with a lot of mech to improve natural convection.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
https://linustechtips.com/topic/518925-fanless-cooling-am3/#findComment-6895462
