Headset advice
Go to solution Solved by weez,
  • Asus Strix Pro
  • HyperX Cloud II
  • Steel Series V3
Which one should I take and why?
Can the Cloud 1 be an option? If so I would get that. If not then I would get the Cloud II then the SteelSeries V3. Reason, reviews have been very good for the Clouds (both 1 and 2) and it comes with velour earpads. Im not a fan of leatherette.
If you want more reasons then do a search for Hyper X Cloud in the search bar :)
I need to get another set of headphones since my friends cat ate the cable of mine.  I was using steel series v3 at the time and it was okay for me mostly playing cs:go and new single player shooters.
I was thinking one of these 3 headsets:
  • Asus Strix Pro
  • HyperX Cloud II
  • Steel Series V3
Beneath this mask there is an idea, and ideas are bulletproof.
https://linustechtips.com/topic/518698-headset-advice/
  • Asus Strix Pro
  • HyperX Cloud II
  • Steel Series V3
PC Audio Setup = Beyerdynamic DT 770 pro 80 ohm and Sennheiser pc37x (also for xbox) hooked up to Schiit Fulla 3
https://linustechtips.com/topic/518698-headset-advice/#findComment-6895173
but why cloud 1 ? I would assume Cloud 2 would be better because it is 2 , I mean like 2 times better.
https://linustechtips.com/topic/518698-headset-advice/#findComment-6897101
The headphones are the same. The mic has apparently been upgraded a little (but lets be honest, its not really noticeable). The Cloud 2 has a usb dongle that imo isnt worth the extra cash over the Cloud I. Thats about it. Here in the US the Cloud I is about $31 less then the Cloud II. I would much rather save the $31. But Im not sure about prices where you live :)
https://linustechtips.com/topic/518698-headset-advice/#findComment-6897441
the version 2 is 100 euros and the first version 75 euros but wouldnt be the 7.1 dongle be very handy in games like counter strike to hear the footsteps?
https://linustechtips.com/topic/518698-headset-advice/#findComment-6900721
You can get 7.1 using software like Razer Surround and its free. But imo, stereo is better for competitive gaming. The dongle isnt worth 25 Euros, imo
https://linustechtips.com/topic/518698-headset-advice/#findComment-6900741
Thanks for the advice appreciate it.
https://linustechtips.com/topic/518698-headset-advice/#findComment-6903083
