It could run a GPU loop in addition, however you might want to check the head pressure of the included pump, and if it's not enough you may need to add in an additional pump. The radiator is *enough* for two blocks but it would result in a higher temperature, and in general one 120mm rad is enough to cool a cpu/gpu, but a 240mm per is recommended.
Me: Computer Engineer. Geek. Nerd.
[Educational] Computer Architecture: Computer Memory Hierarchy
[Educational] Computer Architecture:  What is SSE/AVX? (SIMD)
How would I check my pumps 'head pressure' ?
"Ravioli Ravioli give me the Formuoli"
Try looking at the support pages of the official website of said AIO loop. Its also is possible that its not listed...
P.S. Also, what's the Fins per Inch (FPI) of the radiator? You can easily measure it by counting.... well... the fins per inch.
Can't find pressure specs but flowrate is 120L\hr. Per techpowerup
You could cool a gpu with it but I believe the Triton rad is aluminium so watch out for corrosion issues! If it is a 240mm rad then temps will be higher and need higher fan speeds
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
