Best case?
Go to solution Solved by MLG Doge,
Enthoo pro m
I can vouch
mid tower- full tower
So varying size of ATX.
Other than good cable management, any requirements? Cooler compatibility, HDD bays, 5.25" bays, etc.
Ncase M1 or anything from CaseLabs
Both of those are way over budget.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/518593-best-case/#findComment-6891671
It needs to fit a hyper 212 evo 1 dvd tray and needs to fit 2 HD
3 cases caught my eye searching Overclockers.co.uk, Corsair's 230T, Phanteks' Enthroo Pro M, and maybe In-win's 503.
Unfortunately they're all up to 10 quid over budget.
But I need to get to sleep, so I can't put more effort into helping you tonight. Sorry.
https://linustechtips.com/topic/518593-best-case/#findComment-6891706
£10 above the budget is no big deal :)
https://linustechtips.com/topic/518593-best-case/#findComment-6893814
Enthoo pro m
I can vouch
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/518593-best-case/#findComment-6893819
