should i get a 16gb memory or should i get 8gb with a higher clock speed like 2400.
i will be gaming
CPU: i5 4690k  (overclocked to 4.3ghz)             CPU Cooler: Cryorig h7                 MOBO:  Msi Z97 pc mate             RAM: 8GB HyperX 1600 blue
GPU: rx480  4gb                                                 CASE: Corsair Spec-01 red              OS: Windows 10
PSU: EVGA 500   watt                                       SSD:    v60gb Mushkin ssd                HDD: 1000GB WD BLUE
https://linustechtips.com/topic/518486-16gb-memory-or-higher-speed/
faster ram doesn't matter. get 16gb
CPU: Intel Core i7-5820K @ 4.1GHZ | MOBO: Asus Rampage Extreme V Eatx LGA2011-3 | RAM: 16.00GB DDR4 G-Skills Ripjaws @2400Mhz | GPU: 2x Gtx 980 | CASE: Cooler Master Cosmos 2 | STORAGE: 400GB INTEL 750 Series PCI-E SSD/ 3TB Western Digital WDC | PSU: Corsair AXi 1200w | DISPLAYS: ASUS PB287Q (3840x2160@60Hz) And LG27MU67 (3840x2160@60Hz)
Just buy 16 GB of DDR3-2400, it's barely more expensive than 16 GB of DDR3-1600. And yeah, the speed matters when you're cpu bound. So right now that translates most to minimum framerates in cpu heavy games like Fallout 4 and GTA V, but it might also allow you to squeeze a little more life out of your system in the future when you could be cpu bound more often.
