PSU Help
Go to solution Solved by z97,
Yes
I wanted to have a custom built computer, but circumstances have proven that to not be possible. I have a Dell 8700 and I want to upgrade the PSU and graphics card; but I need help figuring out what power supply is going to fit in it. It is a mid-tower case, and I need at least 650w since I plan to overclock my graphics card (GTX 980).
Here are the current parts to my Dell 8700:
-Intel i7 4790
-GTX 745 (going to upgrade to GTX 980)
-460w PSU (going to upgrade to at least 650w)
-16GB DDR3 RAM (4 x 4GB)
-1TB Hard Drive
https://linustechtips.com/topic/518293-psu-help/
Any psu should fit that as long as it's not a boat.. they are standard ATX.
CPU: I7 5960X @4612 MHZ/1.325Vcore | Cooler: Full custom loop | Mobo: Asus X-99A | GPU: 2 EVGA 980 TI Classifieds | RAM: G.Skill Trident Z 32 GBs 3200 MHZ | Storage: Samsung SM951 512 GB M.2 Drive, Mushkin Eco2 512 GB SSD, Muskin Chronos 480 GB SSD | PSU: Corsair HX 1000i | Case: Fractal define R5 | Monitor: LG 34UC87M-B
https://linustechtips.com/topic/518293-psu-help/#findComment-6888638
Yes
https://linustechtips.com/topic/518293-psu-help/#findComment-6890611
