Here is my old post with all the info:http://linustechtips.com/main/topic/516849-need-upgrading-help/
From this I may be able to squeeze an i7 in without going too over budget.
I'm looking at an i7 4790k
But I know nothing of cpus just gpus
What should I look at?
Cheers!
https://linustechtips.com/topic/518264-need-i7-shopping-help/
your budget still £440? PSU, and CPU?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/518264-need-i7-shopping-help/#findComment-6888269
Would the 4790k suite my needs? what about overclocking?
What games? You can't overclock on your current motherboard.
5800X3D / ASUS X570 Dark Hero / 64GB 3600mhz / EVGA RTX 3090ti FTW3 Ultra / Dell S3422DWG / Razer Deathstalker v2 / Razer Basilisk v3 Pro / Sennheiser HD 600
2021 Razer Blade 14 3070 / iPhone 15 Pro Max
https://linustechtips.com/topic/518264-need-i7-shopping-help/#findComment-6888352
I have the 4790k and with a decent cooler ive gotten a 4.6 ghz 24/7 use stable for 3 months
I have one swell they're great chips, can get mine unto 4.9 but I'm on water. I normally recommend getting the latest platform, however I don't think you could afford Skylake i7 and a new GPU on this budget, so 4790k using the ram you already have maybe the best way to go
Ryzen Ram Guide
https://linustechtips.com/topic/518264-need-i7-shopping-help/#findComment-6888367
The 4790k is a great cpu for both gaming and editing so I highly recommend that.
i5 4690k | MSI GTX 970 Gaming 4G | Swiftech H240-X | MSI Z97s SLI Krait Edition | Corsair Vengeance Pro 8gb ( 2x4gb ) | Corsair RM750 | Samsung 850EVO 250gb SSD & WD Caviar Blue 1tb HDD | Fractal Design Define R5
https://linustechtips.com/topic/518264-need-i7-shopping-help/#findComment-6892061
