Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/518137-cpu-fan-question/#findComment-6886763
What do you mean stock fan? Stock Intel heatsink (Then no)? Stock AMD heatsink (Maybe)?
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/518137-cpu-fan-question/#findComment-6886769
Can I replace the stock 80mm fan on top of my CPU heat sink with a new fan such as this one?
(http://www.newegg.com/Product/Product.aspx?Item=N82E16835186072&cm_re=80mm_fan-_-35-186-072-_-Product)
what kind of cooler do you have
Tsubasa (The 7680x1440 beast): CPU: Intel i7 8086k | Cooler: Fully Custom Rigid Loop MOBO: Asus Z370-I ITX | GPU: Nvidia Titan Xp Star Wars | RAM: 32Gb 2x16gb Gskill Trident Z RGB | SSD: Samsung 1TB 970 Evo Nvme, 2TB Micron Sata SSD | Case: Fractal Design Nano S | PSU: Corsair SF600 With Full custom cables
https://linustechtips.com/topic/518137-cpu-fan-question/#findComment-6886771
what computer or board do you have???
|| CPU Intel Core i7‑4790K 4.9 Ghz || Motherboard MSI Z97S SLI Krait Edition || RAM corsair vengeance pro 4x8gb 2400mhz || GPU msi msi twin frozr gtx 1080 8g sli x2 || Case nzxt phantom 410 || Cooling corsair h100i ||
https://linustechtips.com/topic/518137-cpu-fan-question/#findComment-6886774
Its an AMD CPU, (a10-5700) but the heat sink and fan on top of the heat sink are two different components that are separately screwed on. Can you use the case fan to replace that fan on top of the heat sink?
My motherboard is the
MSI MS-7778 (Jasmine) Edited by Butterybun
https://linustechtips.com/topic/518137-cpu-fan-question/#findComment-6886790
Just going by Google image searches, so long as the stock fan is 80mm, then sure. I won't offer a guarantee though.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/518137-cpu-fan-question/#findComment-6889019
