Hi, I want to know if the temperature of my i7-5820K is alright. Currently it is at about 45-50 degrees. However, when I play some games, it is at about 50-60 degrees. It is clocked at 3.6ghz. I use a Coolermaster Hyper 212X.
CPU: Intel I7-5820K  GPU: Zotac GTX 970 Twin Fan  PSU: Seasonic S12II-620W Storage: WD Blue 1TB & Kingston 120GB SSD  RAM: Crucial Ballistix 4X4 16GB DDR4 2400mhz Audio: Altec Lansing MX5021, Altec Lansing VS4221, Creative SoundBlaster Roar and SoundBlaster Z  Case: Armaggeddon T1X  OS: Windows 10 Pro 64bit Peripherals: Razer Deathstalker Essential, Logitech M280, Xbox One controller with Windows Wireless Adapter
https://linustechtips.com/topic/517985-i7-5820k-temps/
That temp is fine for Intel CPUs,especially under heavy load.You're fine.
Shark Rampage V: AMD FX-4350 @ 4.5GHz(1.404 Volts) / Hyper 212 Evo / Gigabyte 750Ti (1405MHz Core,3200MHz Memory @ stock voltage) / Kington HyperX Fury 8 Gigs 1866MHz Dual channel / ASUS M5A97 R2.0 / WD Caviar Blue 1TB 7200 RPM / 850Evo 250GB / XFX TS 550w 80+ Bronze Sharkoon VG4-W
https://linustechtips.com/topic/517985-i7-5820k-temps/#findComment-6885320
yes, that's fine.
if you wanna push it more, then I'd get a better cooler.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/517985-i7-5820k-temps/#findComment-6885328
What if I overclock it to about 4.2ghz? Will the temperature be over 90 degrees?
https://linustechtips.com/topic/517985-i7-5820k-temps/#findComment-6885334
We don't know. Why? Because each Chip overclockes very differently, so it's quite hard to compare. I wouldn't overclock too hard on a cooler master 212
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/517985-i7-5820k-temps/#findComment-6885343
Okay, thanks for the help.
https://linustechtips.com/topic/517985-i7-5820k-temps/#findComment-6885360
I´d suggest not to push too much on air. The X99 CPUs are quite big and even they´re soldered I´d recommend at least an AIO if you wanted to OC. Because even if your CPU sample doesn´t need that much Voltage, but temps over 75°C are not very desirable IMHO. After all it could shorten the life span of your CPU.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/517985-i7-5820k-temps/#findComment-6885383
with my 5930K 4.4Ghz 1.3V, I get 58-64c when gaming.
GPU[Two GTX 980ti Lightnings overclocked]-CPU[Core i7 5930K, 4.4Ghz]-Motherboard[MSI X99 Godlike]-Case[Corsair 780t Black]-RAM[32GB Corsair Dominator 3000Mhz Light bars]-Storage[samsung 950 Pro 512GB, Samsung 850 Pro 1TB and Samsung 850 Pro 512GB]-CPU Cooler[EK Predator 360mm]-PSU[EVGA 1600w T2 Individual cables Red]-Monitor[ASUS PG348Q]-Keyboard[Corsair K70 Red]-Mouse[Corsair M65 RGB]-Headset[sennheiser G4me one]-Case Fans[beQuiet Silent Wings 2]
https://linustechtips.com/topic/517985-i7-5820k-temps/#findComment-6885508
Thats probably because of watercooling.
https://linustechtips.com/topic/517985-i7-5820k-temps/#findComment-6885590
It is the EK Predator 360mm, just showing what I get at 4.4Ghz while gaming.
https://linustechtips.com/topic/517985-i7-5820k-temps/#findComment-6885596
That's not bad. The temps.
https://linustechtips.com/topic/517985-i7-5820k-temps/#findComment-6885684
