Hi. It's a new year with a new graphics card so i was thinking about increasing my resolution.
I'm wondering, is the amount of pixels you have directly tied to your overall fps? For example, i have a standard 1080 monitor now with a pixel count of 2073600.
I want to get an ultra wide 1440 monitor which should have a pixel count of 4953600. Thats 2.38 times the pixels.
So if i have 100 fps, will i get only 42 if i upgrade to a ultra wide 1440? Or is the fps not quite lowered in sync with the fps increase?
https://linustechtips.com/topic/517890-fps-hit-with-resolution-increase/
Okay.
I have a Nvidia card. Is there a similar program for that?
DSR
I haven't used GeForce Experience in a while, so I don't remember how to enable it.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
Yes, but too drunk to remember the name lol. Happy new year!
Seriously though, Nvidia has one too. So if you have a 1080p monitor you can render the game in 1440. It looks better and let's you see what kind of fps your GPU can provide.
If anyone asks you never saw me.
You will lose 35-40% fps. Downsampling is not the same like a true Resolution.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
Okay. So rendering the game in 1440 or 4k will have the same fps hit as running it native on a better monitor?
EDIT- I just read the question again, sorry. That's correct. If you do that, you'll get a good understanding of how it'll run on a monitor of that resolution.
The Laptop:
Okay. So i just maxed Witcher 3 in simulated 4K and got around 40 frames. So i should expect alot more than that from a 3440 x 1440 monitor then.
Again, downsampling give you not the same Results like true 4k or 1440p.
What kind of a setup do you have? That's beast.
This is true, too. Again, I said expect similar results, not exactly the same results. It'll be different.
The Laptop:
I just finished my project that has been going since summer. Basically i7-4790k and msi gtx 980 ti. Put a slight overclock on the gpu (havent gotten into the idea of raising voltage yet) to achive 40 instead of 37 fps.
So if simulated 4k goes from 100-120 fps down to about 40, how much should true 4k hit the fps if you can estimate.
Depends on your Hardware. 30-35fps in 4k ULTRA are realistic. With a Tweak here and there you can reach the 40. But 4k is not worth the huge fps loss. 1440p is the superior solution.
Those are some nice specs. I don't know about The Witcher 3, but a 980ti can handle some games at 4K over 30 FPS. If you want 60 FPS, I think 1440p is the way to go.
The Laptop:
Okay then that sounds reasonable. Yeah im definitely going ultra wide 1440. Wanted to go 3 monitors for a long time but UW1440 seems like a much better option. I only simulated 4k because it should be much more taxing than UW1440 and i couldnt simulate an ultra wide aspect ratio.
Thanks. The reason it took so long was because i had to sell my old pc in order to afford the gpu :P In hindsight maybe i should've gone with X99 but its no big deal i think.
