Looking to get a cooler for my fx6300. will be oc to 4.0-4.5 ghz max. my case is the Corsair Carbide 100R. 212 Evo doesnt fit so dont bother suggesting it lol.
any help is appreciated. thanks guys :)
Well with the 212 out of the question since it's 9mm too tall there's not a lot of tower style coolers to choose from. You could go with a Noctua U9S or Rajintek Aidos, they come in under 140mm (100R can fit up to 150mm). Or you could go with a low profile cooler like the Rajintek Pallas or Noctua C14S.
Just some options/examples I found. You could also do a Corsair H60 or other 120mm AIO, that would work also and some are cheaper than low profile heatsinks.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/517246-good-cooler-for-my-case/#findComment-6876388
thanks really apprectiate the response i think i might go with an AIO cooler, are there any 240 mm that would fit in my case that you know of?
https://linustechtips.com/topic/517246-good-cooler-for-my-case/#findComment-6879121
Well probably any 240 like the H100 would fit but it will probably take some creative customizing. A 120 would be very simple to install in comparison.
https://linustechtips.com/topic/517246-good-cooler-for-my-case/#findComment-6879964
Where are you shopping/located? Budget?
I don't think it's really worth spending that much on a cooler for a 6300.
https://linustechtips.com/topic/517246-good-cooler-for-my-case/#findComment-6882335
What about the Cryorig H7? I heard it performs better than the 212 EVO and is 145mm tall, with no RAM clearance issues. As for closed loop liquid coolers, anything with a single 120mm rad would fit on the back.
NEED X58 BOARD WITH SATA3 ASAP
https://linustechtips.com/topic/517246-good-cooler-for-my-case/#findComment-6882537
If you're in a country that Cryorig products are available, or you're willing to import this is the option I'd choose.
Though a good topflow cooler could work well too. Not sure which I'd recommend though, not a type of cooler I look at all that often.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/517246-good-cooler-for-my-case/#findComment-6882563
