Hi I'd like to set up a server at my house which would act as a NAS and as a web proxy for me to connect to from other networks. I was wondering how I should set this up. I was originally going to use FreeNAS but I'm not sure if I could do the proxy part with this OS. What OS should I use and how should I go around setting it up. Thanks!
https://linustechtips.com/topic/517169-home-server-help/
freenas for the nas part
and use teamviewers vpn built in option
http://www.smartpctricks.com/2013/05/how-to-setup-configure-free-vpn-virtual-private-network-with-team-viewer-vpn-client-software.html
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/517169-home-server-help/#findComment-6875501
Thank you very much! This looks like exactly what I wanted
https://linustechtips.com/topic/517169-home-server-help/#findComment-6875612
