Simple question need simple answer
Go to solution Solved by 007agentHP,
if only 144Hz
it is 144hz
http://www.amazon.com/PB278Q-2560x1440-DisplayPort-Ergonomic-Back-lit/dp/B009C3M7H0/ref=sr_1_2?s=pc&ie=UTF8&qid=1451534015&sr=1-2&keywords=asus+27in+144Hz
Can I OC this to 144Hz?
and if not...
Can I get a 2k+ reso ips (or similar same thing) for around 400$ 144Hz is a must.
Been searching all over and need this to go with the evga 980 TI I just bought
@WhOaMi_Gaming
id/theoriginalwhoami
https://linustechtips.com/topic/517122-simple-question-need-simple-answer/
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
and if not...
Monitor overclocking is the same as overclocking where it's a lottery, at times some monitor units will do fine being pushed but others may not even do +1Hz.
Hmmm  , I am looking but do not see it.
If it is I am buying.. Just found this though http://www.newegg.com/Product/Product.aspx?Item=N82E16824236593
@WhOaMi_Gaming
if only 144Hz
it is 144hz
Rigs I've Built
