I built a water cooled computer at the start of this year with a 4790k and a GTX 980. It ran great and I have continued tinkering it too this day and it has evolved quite a bit. Its current revision, photo and specs down below, I am a little confused by the temperatures. At idle both my 4790k and GTX 980 run below 30 degrees which I am fine with as the ambient temperature here is around 25C anyway. However, once under load my CPU temps can reach up to the low 70s and my GPU (overclocked to 1530Mhz) reaches high 60s. I don't believe my temps have ever been this poor and am unsure whether its just the hot Australian summer or if the cooling performance of my loop is degrading. It appears to me that my radiators are not doing a sufficient job of dissipating the heat of my loop for some reason as my coolant temps (monitored through a bitspower probe in the pump block) reach about 55 degrees.
Could it be also because my coolant needs replacing? I am using Alphacool CKC and have been using it for about 9 months.
Any suggestions as to what it could be would be great. Thanks.
Specs:
i7 4790k
GTX 980 (OC 1530Mhz)
Asus z97 Pro
Hyper X fury
Cooling specs:
Front Rad: EK cool steam 240 with two Ek-Furious Vardar fans
Top Rad: Ek cool stream 360 SLIM with three performance edition Corsair SP 120's
CPU block: Ek Supremacy Evo
GPU block: Ek Full cover Acetal Nickel
Pump/Res: Ek-XRES 140 DDC 3.2 PWM
Coolant: Alphacool CKC + Mayhems Deep Purple Dye
Tubing: Ek 12/16 PETG
https://linustechtips.com/topic/516948-custom-loop-temps/
Is the PC getting enough airflow? The back of it looks pretty block off there. So the hot air being pumped out of the raidiators could just be sitting around the PC and being sucked back through meaning its not really getting any "fresh" air to cool the system.
01000100 01100001 01110010 01110101 01100100 01100101 00100000 00101101 00100000 01010011 01100001 01101110 01100100 01110011 01110100 01101111 01110010 01101101
https://linustechtips.com/topic/516948-custom-loop-temps/#findComment-6872913
-SNIP-
Nice purple build, but as for temps those initial temps aren't bad and you do have more than enough rad space for cooling, but how far are you overclocking everything?
Also just as a test to make sure it's not an airflow problem take off the top panels of the case to see if temps drop significantly.
https://linustechtips.com/topic/516948-custom-loop-temps/#findComment-6872953
The photo is on the side so that is actually the top of the case haha
Will do, thanks for the suggestion
https://linustechtips.com/topic/516948-custom-loop-temps/#findComment-6873103
It looks like it got shoved in the corner too much. Try bringing it into an open space and testing it.
Also you need to make sure your room isn't increasing in temps too much.
High 50s low 60s is what I would expect on both
55C coolant temps is really really bad.
I can't get my coolant temp over 43C
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/516948-custom-loop-temps/#findComment-6873255
Just tested without the top or side panels on and temps dropped by nearly 10 degrees. Might do a bit of modding to allow for more airflow haha My case is an Enthoo Evolv, great case, but shit airflow it would appear
My computer is in a very open space, sorry, the forum rotated the photo so it is hard to get an idea of the space. Just tested with my top and front panel off and therefore unrestricted airflow and temps dropped nearly 10 degrees on both CPU and GPU.
https://linustechtips.com/topic/516948-custom-loop-temps/#findComment-6873295
10 lower would be more reasonable... What case is that?
The front in particular looks fairly restrictive.
https://linustechtips.com/topic/516948-custom-loop-temps/#findComment-6873307
Phantex Enthoo Evolv ATX. Amazing case, absolutely love it, but yeah, air flow is not amazing. http://www.phanteks.com/Enthoo-Evolv-ATX.html
https://linustechtips.com/topic/516948-custom-loop-temps/#findComment-6873382
Yeah it seems like the top panel isn't giving much airflow out of the case other than the side vents on it.
https://linustechtips.com/topic/516948-custom-loop-temps/#findComment-6873402
Nice looking computer!
Coolant age won't change its heat transferring ability unless you had crap growing and circulating around your system clogging things. Though then it would be the clogs not the coolant that is the problem.
Also could you edit your OP with a better pic? Far enough back to not cut off the front of the case and rotated properly would help people not be confused. I'm guessing you used an iPhone? They seem to not rotate pics properly so take the photo in portrait and crop it before uploading rather than using a landscape shot. Should fix the problem.
https://linustechtips.com/topic/516948-custom-loop-temps/#findComment-6874183
Thanks!
Been trying to upload a new photo but just keeps rotating them. I am using a Galaxy S5 and it appears to be the forum rotating them and not me. I even tried to pre-rotate the photo in the opposite direction but it still seems to upload it on the same side haha Will keep trying.
https://linustechtips.com/topic/516948-custom-loop-temps/#findComment-6882993
