Hey guys, So I got a ton of recommendations from my other post and I just wanted to know what you guys think of this build. I'm not planning to overclock anytime soon so this is just basically a simple build with no overclock or fan stuff or temperature and everything. Tell me what you guys think about it, I'm open to any suggestions :) http://pcpartpicker.com/p/X3GdBm My budget is $1200-$1230
https://linustechtips.com/topic/516443-first-build-pt2/
hmmm okay, I'm not really sure how to overclock but I'll look into it. Thank you man.
Its not too difficult there are plenty of tutorials and It just means you can keep your speed up with an extended period of time. I also didn't see a CPU cooler in your build I would highly recommend one instead of using stock one. Cooler Master 212 Evo is a common and good one.
https://linustechtips.com/topic/516443-first-build-pt2/#findComment-6867449
Do I need a cpu cooler in my build? I'm not really running much unless I REALLY need it, It's a hassle trying to install the CPU cooler, i'm legit the noobest builder on this planet and yeah...
https://linustechtips.com/topic/516443-first-build-pt2/#findComment-6867457
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor  ($219.99 @ SuperBiiz)
Motherboard: Asus H170 PRO GAMING ATX LGA1151 Motherboard  ($124.99 @ Micro Center)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($81.49 @ OutletPC)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($343.98 @ Newegg)
Case: NZXT S340 (White) ATX Mid Tower Case  ($63.99 @ SuperBiiz)
Monitor: BenQ XL2411Z 144Hz 24.0" Monitor  ($249.00 @ Amazon)
Total: $1298.40
Generated by PCPartPicker 2015-12-30 02:37 EST-0500
Much better
https://linustechtips.com/topic/516443-first-build-pt2/#findComment-6867459
Total: $1298.40
Much better
I see, I'm not really looking for a 16gb because I think it may be too much, but the cpu? is it better?
https://linustechtips.com/topic/516443-first-build-pt2/#findComment-6867467
Well if you are planning on gaming on it it does keep the temperatures down and at a more comfortable level but the stock ones do work fine, but I do always recommend getting an after market cooler
https://linustechtips.com/topic/516443-first-build-pt2/#findComment-6867470
Total: $1298.40
Much better
Barely any difference in performance between the 6500 and 6600. 16GB is overkill for gaming. XFX PSUs are much more reliable and its cheaper.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/516443-first-build-pt2/#findComment-6867477
Pleeeeese don't get a sapphire card. I have had terrible experiences with their cards and I wouldn't want anyone else to suffer through their truly atrocious customer service.
CPU: Intel Core i5-4460Motherboard: Asus Z97-A/USB 3.1Memory: G.Skill Ripjaws X Series 8GBStorage: A-Data Premier Pro SP900 128GBGPU: Sapphire Radeon R9 290 4GB Tri-X OC Video CardCase: Corsair SPEC-01 REDPower Supply: EVGA 600BNetworking Card: TP-Link TL-WDN4800Monitor: Asus VG248QE 144Hz 24.0" MonitorKeyboard: Razer BlackWidow Tournament Edition (Cherry MX Blue) Mouse: Logitech G100s | Quote me and say "Dope Flamingo" if you actually read this.
https://linustechtips.com/topic/516443-first-build-pt2/#findComment-6867535
Seems good. There are a few places where you can save on cost. Assuming you're in the US, you can save ~$50 on your graphics card choice by ordering from jet dot com (if it's your first time placing an order).  Just checked, they have a 319.99 r9 390 card so that'd run you 270 or a little less if you waived the return fee. Issue is that jet is slow on delivery/fulfillment - like 10-14 days from the time you order.
https://linustechtips.com/topic/516443-first-build-pt2/#findComment-6867660
which would you recommend then?
Msi or Gigabyte
https://linustechtips.com/topic/516443-first-build-pt2/#findComment-6875367
