does any one know of a good UPS. I am looking for 2 one to power NighHawk and the other to power my parent's old desktop. My parent's pc never draws more than 400W and Nighthawk does about 550W. I don't want to spend more than 120$ for both.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/516262-ups/
Find one from a reputable brand with capacity for at least 600 VA. That should be enough for each, if you're going to get two.
ok, yeah 2 because they are in different rooms.
https://linustechtips.com/topic/516262-ups/#findComment-6865487
I would recommend this from APC, but what are the specs of the system we can get a better idea of what is required:
http://www.apc.com/shop/us/en/products/APC-Power-Saving-Back-UPS-750/P-BE750G
https://linustechtips.com/topic/516262-ups/#findComment-6865841
NightHawk is in my signature and my parents PC is a I-2 quad, HD5750 and 1 HDD with a Antec basic power supply.
https://linustechtips.com/topic/516262-ups/#findComment-6866072
For your system your going to want a slightly larger unit since the 750VA is only capable of 450W. Something like this can do a fair bit more than you need including peripherals and networking equipment included:
http://www.apc.com/shop/us/en/products/APC-Power-Saving-Back-UPS-Pro-1000/P-BR1000G
https://linustechtips.com/topic/516262-ups/#findComment-6866130
Ok will get one of each, a bit more than I wanted to spend but whatever.
thanks
https://linustechtips.com/topic/516262-ups/#findComment-6866143
